which bolt/ bolts to mount mutazu
MUTAZA
i recently bought mutazu bags (https://www.ebay.com/itm/Detachable...DSTER-RS-ST-w-mounting-brackets-/231854436544)
for my recently bought 09 phantom spyder, i see a couple of you have these bags, i am curious which bolts on the bike you mounted the brackets on, is it under the seat or did you cut the plastics?
any help would be great, pictures would be even better, thanks.
jeff[/QUOTE].... A member here named Von Baden - posted quite a lot about these bags including PICS .... another member had one fall off :yikes: ........... I have the bags and when I mount them I plan to weld a NUT to the middle of the bracket so I can put a BOLT thru the center of the Bag into that nut .... this will prevent an accidental loose ..... Mike :thumbup:
