Rawhide kid
"Cold" here in AZ, so doing some farkles and other work. Did first oil and filter change - took awhile but gotrdone. Then put in new louder Horn, no problem. Added Highway pegs, no problem. Swapped out Bajaron Sway bar. Some issues but Ron was very helpful via email.
I had added a heated (used) Corbin seat. Not that I need heat much here in AZ, but occasionally on cold 50 degree mornings it would be nice. I found the accessories site in fuze box on right side. Plugged it into that and it works, but it is "hot always". Given that the switches are on the side of the seat, I worry about accidentally leaving them on and draining the battery.
So.....how or where can I tap into a switched wire for the seat? I'm not electrically inclined (as perhaps you can tell), so worried more than a little about doing something wrong. Searched here in DIY section, not finding much. I also want to hook up a USB and wouldn't mind it being switched hot as well.
Thanks for any help.
