Where to look to get more handlebar cable slack on 2020+ RT models?
troop
Well-known member
Hey all 2020+ RT owners,
I'm wondering where to look under the side panels to get more handlebar cable slack for my 2022 RT S2S? I took off the wire loom clip at the top and just removed the (3) panels on both sides. The left side cable is nowhere to be found. I found a zip tie around two looms on the right side, but neither of those appears to be the throttle side bar loom. I have Helibars installed and would like to get just a bit more slack. Thoughts? Thanks.
Please excuse me if I'm missing something, but your descriptions in the 3rd and 4th sentences confuse me regarding which way you are looking for and at the cable looms. In the 3rd sentence you say the left side cable is nowhere to be found. Does that mean you cannot find the loom from the left handlebar control module that controls all the functions on the left handlebar in pg 18 of your Operator's Guide? In the 4th sentence you say you found a zip tie around to (I assume you mean two) looms on the right side, but neither of those to be the throttle side bar loom, those functions on the right handlebar in pg. 18. By convention, left and right are as the operator sits on the roadster.
Ha ... OK.
1.) By saying I can't find the left side (clutch side per se) cable, I meant as it runs down into the console area into the front cavity. I can't find where it runs inside the left area behind where the panels were removed.
2.) On the right/throttle side, I try to follow the control cables as they also run down from the front console area into the cavity. I found two thick wire looms down on the right side that were zip tied into a cable stay. After cutting the zip tie, I was unable to pull more of the throttle side cabling to get a bit more slack.
Maybe there is no more slack to be had?
