Where is the F3T Customer Accessory Circuit fuse location?
Haze
Well-known member
Where is the 2017 F3T Customer Accessory Circuits fuse location?
Are all 3 Accessory circuits wired to the same fuse or fused independently?
What is/are the total watts available for accessories?
I don't have a service manual - yet.
I plan to add:
1. GPS
2. USB Charging Port for an XM Radio and Cell phone
3. Fog Lights using the OEM Wiring harness with aftermarket led lights
4. Signature Light using the OEM accessory circuit wiring harness in the Frunk
5. Port for Heated Gear. Hope to use the accessory circuit that is under the seat. This connection will also be for my battery tender.
6. Oxford Heated Grips - not OEM.
7. Additional led accent lights
Thanks, David C.
Where is the 2017 F3T Customer Accessory Circuits fuse location?. Looking at the battery from the front of the spyder with the frunk liner out its the sixth Spade fuse from the top left in the left hand fuse box.
Are all 3 Accessory circuits wired to the same fuse or fused independently?. all 3 Accessory circuits share the same fuse and only receive power with engine running so would be no good for a battery tender.
What is/are the total watts available for accessories?. Fuse is 10 Amp so that would make it about 120 watts. Heated grips draw about 4.2 Amp twin port USB fast charger draws 4.8 Amp heated gloves 2 Amp heated jacket around 7.5 Amp. Best bet would be to hook heated gear and Heated Grips to the battery. Oxford grips power down after shutting off motor so won't drain the battery. Signature Light GPS USB charger and accent lights hooked up to Customer Accessory Circuit would leave a little head room depending how mad you go with the accent lights as long as you keep it south of 10 Amp your golden
