How would anyone know if the caster & camber alignment is within specs---possible tire wear or steering pull --then what ??
Steering pull is one sign, tire wear another, but before you get anywhere near that far there are many other signs & symptoms, & any or all of them can be indicators of poor or incorrect camber or caster settings. Things like erratic road holding, wandering when you are trying to ride straight; a bit of vibration or shimmy after hitting a bump that takes a few seconds to settle; a steering 'rattle' or shimmy at a certain speed or in a given speed range; 'darty' steering, when the bike seems to react/veer very quickly in response to the tiniest of steering input; heavy steering; tram lining on barely noticeable surface imperfections; a tendency to plow straight ahead on a corner before suddenly responding; in fact, just about ANY &/or ALL of the complaints people on this & other forums have ever posted with regard to their Spyder steering could be as a result of incorrect settings apart from just toe in/out discrepancies.
At the worst end of running 'incorrect or out of spec caster or camber settings' you can end up with settings that either refuse to let your bike turn regardless of where the wheels are pointed, or at the other extreme, finding your steering has a 'point of no return' where the steering goes so far & then suddenly slams over to full lock & you are completely unable to turn it straight again....
On our Spyder suspensions, Camber & Caster will vary a little on where the bike is sitting in the full range of its suspension travel, so different weight riders will probably end up with different settings on their bikes - changing the front suspension pre-load can help reduce this or get it within the designed spec range. There WILL be a 'design spec' (probably a range of a couple of degrees for either/both) somewhere that the engineers who originally designed the front suspension & steering worked out would be best for these bikes, but unless we know it & whoever does the 'wheel alignment' is aware of it AND your usual riding load, it's pretty much a 'take what you can get & put up with the handling AND THE POTENTIAL SAFETY ISSUES that riding your bike with incorrect caster & camber settings can bring!!
The fact that so many Spyders DO have steering & handling issues from the dealer teamed with the fact that this sort of suspension DOES vary camber & caster depending on where the suspension happens to be sitting when loaded strongly suggests that knowing what it should be & aiming for that when getting your alignment done might be helpful & potentially a whole lot safer - and before you say that camber & caster are set & cannot be changed, that's crap!! It's just not as easy as correcting the toe in/out or connecting it to BUDS & it does take some knowledge & skill to do it properly. But there are ways to adjust suspension height as well as adjusting the camber, caster, steering angles, steering pre-load, etc - all of which are regularly being adjusted & changed to suit various needs on other vehicles with similar suspension & steering that is supposedly 'set by the factory'!! Much of the time changing or correcting these 'pre-set' angles just require the operator being aware of what the settings are vs what they should be so that they can choose & install the correct shim, bush, or bolt in the right place; and that's even before you start getting into the real skills of 'wheel alignment' or the vast range of after-market adjustable suspension & steering components that is available today!!
