Where do 2021 RT L pass arm rests attach - the top case or the bike?
If BRP armrests are installed on a 21 RT L do they attach to the top case or to the bike? If I want to remove the top case I would like for the arm rests to also be removed.
Thanks
Thanks
Sorry, but the OEM BRP arm rests attach to the Spyder and are not easy to remove.....:thumbup:...Bill
"And the panel that takes the place of the top case will not fit with the arm rests on."
Show Chrome- Here is the write up
Can-Am Spyder F3 Limited (SE6) / Spyder RT Limited (SE6) 2020, Deluxe Series Black Armrest System by Show Chrome®. This Deluxe Armrest System is the ultimate in styling and comfort. The billet forged aluminum brackets are CNC finished and mount to the trunk. The socketed attachment of the swing arm does not intereferewith the trunk opening and swings fully out of the way for passenger access.
The OEM arm rests go on & come off in less than ten minutes. I only use them for long trips with my wife. I've done it no big deal!
Once taken off would the panel then easily be installed if you wanted to ride without top case?
