Where are the "stamped" VIN and Engine #'s
It's mythical I've decided.
Ok just to document this for the next person going through it who starts to Google for an answer. I talked to 2 independent Can Am dealer Service Managers and both insisted the only place there is a VIN is on the swingarm due to its "survivability" (that was cheery to learn) compared to the frame. I also spoke to a Sacramanto DMV field tech who stated the swing arm placard should be sufficient. Back to DMV I go all hopeful for a resolution. How naive of me. Talk to the same guy and he tells me that if the bike only has one VIN then I have to go to CHP for verification and that's what he was trying to tell me in the morning at my first visit. Maybe I missed it but I do not remember him being clear about that at all. So now I have an appt. in 2 weeks at CHP.
The plusses so far - well I've certainly been around and under the bike now and I've pulled my first panel and located the engine number. I have a 30 day temp registration thanks to a DMV manager, as opposed to the 1 day trip pass good for CHP visit only the inspector was going to give me, but that's about it.
The minuses - Calif Registration fee brought a tear to my wife's eye and mine. So many things we could have bought even though we knew it was coming. 2 trips to DMV both ending in failure and pretty much a day wasted.
Pete, I don't have a ramp but I've reached out to a friend who does but not sure I'll bother if I have to go through it all again at CHP anyway. If I do find a VIN on the frame I'll post it in the hopes it saves someone else the time. I will say the people at the shops said that because BRP has different manufacturers over time what may be on one persons bike and where may not be on someone else's. i'll also echo others in that different DMV's may not give a rats ass about any of this and just sign you off. Unfortunately mine is not one of those.
Or 'mystical'
Below I've posted a picture on this thread from Chupaca. It shows the 'stamped' VIN on the right side of the frame behind the front wheels. It would be easier to see if the Spyder is in the air (like on ramps) but not impossible if it's on the ground.
Thanks Pete and Chupaka. I’ve looked at this photo a bunch of times but never saw that. Will check later when the sun sets and a flashlight does better good.
Appreciate the help Pete and to about 4 other folks I’ve reached out to.
P.S. If it is there that sure isn’t where the manual is picturing it.
Your right....
Will a 2015 VIN be in the same spot as in pic 3? Granted you may have no way of knowing that....l
Don't know about the triple but would think it is. Hopefully someone with a 1330 can check. The F3 should have a clear view ....:dontknow:
Got back under the bike in better lighting conditions today and still no luck. The VIN isn't on the frame on the 2015 although it may be covered by plastic somewhere.
What a great community!
Pete in response to your question the image can be found here:
http://www.spyderlovers.com/forums/showthread.php?100687-VIN-Number
Bob posted it up in another thread about VIN in Jan of 2017.
I also reached out to PapaHotel who has a brand new granddaughter and still stuck his head under the bike to help me out. Here is is response:
"Found it, but this won't be easy. Stick your head behind the drivers side (left) tire. look between the upper/lower A-arms (I.E. about 10 inches above the ground.) Look towards the front, see the radiator. Now look to the inboard side of the radiator. It is there, inscribed into the frame. And now we now why they also put a copy on the swing arm... You might have to pull the tire or a panel to get a camera in there, or if you have a friend with a borescope (also now available for your cell phone for cheap), he might be able to document the thing with out too much trouble."
So since I'm not pulling the bike apart I'm hoping CHP will have whatever is necessary to see what they need to see. I did look where he said and yes there are numbers inscribed into the frame but I can't see more than 3 of them Will follow up after that appointment in 2 weeks.
Just want to say this is a great group and I appreciate all your help! :bowdown:
UPDATE: Just spoke to CHP. They only need to validate VIN in one place while DMV requires 2. May be easier for Calif. folks to just start there.
mine is really easy to see 2014RT
not on the left but on the right
turn bars fully to the right
come from the front (on your knees) and stick head between right side upper and lower control arms
look inboard and see vin at front(all of it)
vin is vertical between the 2 spars
maybee ozzy bikes are specced different
good luck
russ
attachment.php
Wow! I need to find this. We have road blocks here off and on, and the Federal Police will stop you and check your paperwork with the Vin. I had not thought of this! Yikes....makes it hard. I will have to be able to find this to show them and that way they verify and let me on my way! ugg....that is hard if I have to remove tupperware?!
Look at the insurance Id Card & your Registration for the VIN #. Deanna
Thank you CHiP!
Got to CHiP 20 mins early and a very friendly officer took care of the vin and engine number inspection in about 10 mins. Should have gone there in the first place so take note anyone following in my footsteps.
I did take a drill driver with me though to get at engine number easily which he appreciated. Thanks to everyone here who contributed to teaching me where to and how to do that. Now I’m a bit more comfortable pulling Tupperware as a result.
One final trip to DMV to go to get the new paperwork processed and a Ca plate.
Spent many hours trying to find the stamped VIN on my 2015 RTS. In case anyone else finds this thread via search, the location is different from the one shown for the 2014. To find the VIN, turn the handlebars all the way left and go the right side of the bike. There are two bars that come out from the bike to connect to the right wheel, one on top of the other. Look between them (you’ll need to crouch down) all the way into the center of the bike. Use a flashlight and look for a vertical metal bar (mine was black), the number is stamped sideways on that vertical bar. It may well be covered in dirt, and the writing is quite small (maybe 3/8” tall).
Hope this helps someone!
~gwh
~gwh
Check your motorcycle insurance ID card for the VIN number, it is listed on there.
Deanna
