Wheel weight removel
sandman53
I am going to change tires soon and hoping to remove all the wheel weight's without damage to the wheel. Any secret's?:dontknow:
They are just held on by sticky-back tape. I use a sharp knife to get under them and them pry them up. Be careful not to nick the aluminum.
Then use alcohol to get the sticky substance off.
Not the only way, but one that works.
Pre soak..!!
Spray some WD40 or other glue removers and then pry them up. I have heard dental floss cut through nicely..then clean with alcohol so new ones will adhear..:thumbup:
Soft pry
I use a plastic spatula called a bone. A Popsicle stick or a tongue depressor works great. Anything softer than the wheel. Then clean up with goo gone.
WD-40
WD-40, let stand for 30 minutes, then go for a ride... when you get back they'll be gone.... :clap:
