900Dave
So I decided to remove the rear tire myself so I could have my new Kumho installed Monday.
First problem, I could not get the bottom shock bolt out. I have an Elka on the back and had this bolt out a couple of times. I had to beat the bolt out. The steel bushing that the bolt goes thru is bent. Ok I will try to straiten it out on the hydraulic press at work, if that don't work I will have the local machine shop make a new one.
So I get the rear tire off, remove the brake rotor and I cannot turn the wheel bearings by hand on either side. The only one that turns is the bearing in the sprocket. Is this normal? I would think they would turn freely. Are the wheel bearings a Warranty item? I still have 8 months left on my extended warranty.
By the way it is a 13 ST- Limited with 21,000 miles.
