Rob Rodriguez
Thanks for your comments but you're way off with your wish for a narrower track, if anything the Ryker needs to be wider. The Ryker has a terrible suspension system so the tires are seldom on the ground in anything less than a perfect road surface. During curves, over-steer is constantly lifting the tire causing it to lose track.
Ryker's biggest poor handling problem is the result over sensitive steering because BRP deleted the electric steering unit.
Secondly, you don't want to lighten the Ryker any more than it is. It's already 400 lbs lighter than a Spyder. Being light is another problem because there is insufficient weight on the front tires to keep them on the ground which results in the front end sliding after any road imperfection. This same problem of being too light results in a traction problem in the rear as well, which causes the back end to shift during even moderate acceleration in a turn.
If anything a heavier rider or adding weight will improve the Ryker's handling!
Regards Mike
Everyone will have a different opinion on this but I have to say I just don't agree with you on this. I'm not saying your wrong, just saying I don't agree. My opinion is based on a Spyder RS and it looks like you are riding an F3 so that may be why our opinions differ?
I have both a 2012 Spyder RS and a 2019 Ryker Rally. There are roads in my area that are both twisty and rough. Really rough in a car, worse on a bike. Some of these roads are on regular routes I ride and I have ridden both the RS and the Ryker over these roads and sometimes on the same day. I can say with 100% surety that the RS offers a smoother more comfortable ride over this terrain. I can also say with 100% surety both the RS and the Ryker "handle" the terrain the same. Handle meaning, the line they hold, the steering input and feedback, the controlability. They are both able to handle the terrain with equal ability at the same speeds. While the RS does provide a more comfy ride I have the same level of confidence in the handling of both bikes. I have never experienced the tire hopping/lifting, tire sliding and traction loss that you describe on either bike. Yes, with the Ryker in Sport or Rally mode I can break the rear tire lose and slide the back around but it has to be an intentional act. It doesn't just randomly happen because I encounter a rough road.
