What's the suggestion for Adding Cruise Control to an F3?
I purchased the right handlebar cruise control unit from BRP for my 15 F3 base model, in approximately two hours worth of time, I had cruise control. Plug and play.
Another cruise control question. Sorry.
I have a 2018 F3 base model, and I understand I can add factory cruise control by simply adding a F3 Sport or Touring RH switch housing.
However, in searching Spyder forums, I come up with different part numbers. I think one part number may have superseded the other.
Does anyone know the correct part number to order , and , if you know who has the lowest price on this part, I would appreciate you efforts very much!
Thanks!
Brian in Tucson
Thanks!
Brian in Tucson
Go to any of the after-market parts sellers ..... type in the number/s you have and then click on " what years & models they are used on " .....Mike :thumbup:
Adding Cruise Control to 2023 F3 Base
Any owners of newer model F3 Base Spyders had success with adding cruise control????
Thinking of picking up a 2023 F3 Base but the only thing would be missing is cruise control. Did a search on here and the web and see that others have added cruise to their Spyders --but they were older models. Pretty much a plug n play install. Have not been able to find any info on the newer models. The RH Switch Housing #710004583 off a 2023 F3-S should do the trick.
Figured I would ask here first before I checked and asked around at some dealerships.
Thanks
Yes Joe, all you need to do is replace the right hand switch controls with one that has the cruise switch. Then just unplug your old and plug in the new ad volia you have cruise control!! Oh and about $ 400.00 less in your bank account!!!
Al in Kazoo
Thanks for the info Al. Just ran across a review that someone with a 2020 F3 base that switched them out and worked fine. Looks like the RH Switch Housing #710004583 will set me back $275.
