What's the correct Krickit reading for an RT's belt tension?
joekeys
What should the Krikit reading be for a Spyder RT be, for the correct drive belt tension?
Tension depends on year and model .... You didn't provide that info .... But I did check your other posts .... for 2015 RT I ONLY measure it ON-THE-GROUND. , and like a little less tension than OEM spec.... so mine is around 160 lbs. measured in the middle of the belt..... At that tension my belt vibes dis-appeared ..... Mike :thumbup:
