What USB Charging and Cigarette Ports are in the Rear Trunk & Glove Box? '23 RTL
Fjrwillie
It is my understanding the 2023 RTL has either a USB charging port or one that is a cigarette female plug in the rear trunk. Someone posted a picture of the one in the rear trunk on another thread, however, I heard it is a cigarette plug female adaptor. I also understand it is not so obvious that one is even there. Can someone confirm if it is a USB plug or a cigarette adaptor?
I usually run with 2 GPS. One a Zumo XT, the other a Nuvi 1490 which outperforms the Zumo. Does anyone know if with the USB port I can run a power splitter, so that I can plug in a USB to Cigarette adaptor and power both the Zumo and the Nuvi?
The following is an explanation and can be skipped for purposes of answering my questions.
Ok, the question of why do I run 2 GPS's? I participate in nationwide scavenger hunts that are run by different organizations, which require their own flags to be present on the bike and included in the picture you take as proof you were there. Basecamp and Mapsource enable multiple symbols to be assigned to the waypoints. When you send the routes from Basecamp to the Zumo all of the Waypoint symbols are changed to these ugly green hearts which I use to remind me of which flag I am going to need to be included in the photo. The Nuvi accepts the symbols you set in Basecamp, so I use this as the reference to assist in the flag selection.
In addition, I upload the tracks from the Nuvi to Mapsource software, which has the timestamp at each Waypoint. I have a piece of software (Geosetter) that matches the timestamp from the GPS to the timestamp in the photo data and records the GPS coordinates to the photo data. This enables me to click on the photo and be able to see where I was in Google maps at the time.
If I upload the tracks from the Zumo, all those ugly green flags change the symbols in Basecamp to blue flags, which destroys my tracking method in Basecamp. Hence, Mapsource lives on!!
Willie
In the attached photo the RED Dots are completed visits. The yellow and red symbols are for 1 Grand Tour, the Baseballs are for another GT (Race Tracks).
My 2022 S2S has two usb ports in the trunk, in the Frunk you would have to add your own charging port, if you use the SAE cord for the battery tender, you can get a usb to sae adapter or I have a SAE to Female cigarette plug for the tire pump, but you can add a usb plug for that also
My 2024 S2S has two USB ports in the top case (trunk) and one USB port in the glove box in front of the handlebars.
There is no cigarette lighter female plug anywhere that I've found.
I power my Garmin Zumo XT from the USB port in the glove box.
The title of my post was changed and not intending for the Frunk, but the front compartment or old term glove box.
Willie
Perfect!!
Willie
I know that there are some differences between the 2023 and 2024 RT models, so I looked at the 2023 Operator's Guide, and there is a big difference in the connectors in the glove box.
You can view the 2023 Operator's Guide here:
https://operatorsguides.brp.com/public/tmp/219002275-RMO23-EN-WEB.pdf
Page 56 of the 2023 guide shows there are two connectors in the 2023 glove box. One is a USB port, and one is an audio connector.
If you connect an audio source to the audio connector it can play through the speakers. There is a caveat that says:
Depending your device, it can be totally, partially or not controlled through the ECC and the keypad.
ECC = Electronic command center (a section of the controls on the left hand grip).
Willie
Sorry, but your original thread title was more than a little confusing, didn't ask the question (or any question for that matter... :rolleyes: ) and as a result, it wasn't getting anything much in the way of views, let alone responses. :shocked:
So I read the text of your first post and took a 'best guess'. :dontknow: . And then you got some responses! :ohyea:
No worries .... I still got the answers I was seeking ... whats a bit of confusion between friends
Willie
