What trailer hitch for a 2023 S2S?
Does this wiring harness allow me to tow my Escapade trailer? I know the Spyder has a CANbus wiring system and the Escapade has to us system but I would like to use that trailer if possible.
I have no idea what your Escapade trailer requires or what connection it uses. Something you need to explore. If it has separate turn signals from the brake and tail lights then you would need the 5 pin. If your Escapade has a combination brake, taillight, and turn signal then you would need a 4 pin. If the Escapade doesn't use a flat pin connection then you would either need to remove what it has and wire on a flat pin connector or build an adapter to convert a flat pin connector to whatever the Escapade has.
The harness is isolated from the bike with relays (solid state) so it will accommodate any trailer loads your trailer presents. So it is just a matter of pinouts to match your trailer.
