What is the Sump plug torque meant to be?
frankclock
Can someone please tell me what tension I should tighten Sump plug and Magnetic plug to
the manual says 30nm for sump plus
it just seems quite heavy to my I dont want to strip it
The torque specifications are for clean, dry threads. Any oil plug that goes in the bottom of a sump will never have clean, dry threads. The oil on the threads will allow the plugs to easily be over-tightened.
Don't know of any torque specs that apply to oily threads. I just tighten the plugs with a shorty ratchet until they contact and then about a 1/4 turn more. I don't use the metal crush washers neither. I use these.......
https://www.amazon.com/AUTOHAUX-Bronze-Engine-Bonded-Gaskets/dp/B07TH2D42H
they are like fiber sandwich washers, made for car drain plugs, but work well on the Spyder plugs.
Never had a leak and easy to get the plugs out next time.
M6 and M27 for 2019 F3-S.................... Don't know what size you might need.
