What is the MPG?
Depends on rpm
I got high 20's (mpg's) at first until I started consistently running at ~5200 rpms...now I get 33.5 mpg on average. Should allow a safe range of ~ 180 - 195 miles. That means running at rpm's that are most efficient, not necessarily the lowest in each gear.
Depends..!
on many things..check posts and threads. I get as low as 25 and as high as 40 mpg's but on average about 33. Mine is an RS and I ryde it hard. Always over 5,000 rpm's on backroads and over 80 mph on freeways. You will have to work up your own data cause it will be different from ours. Don't fret the little stuff enjoy the ryde...:ohyea::ohyea:
With only 1200 miles on the clock I'm getting between 30- 35 mpg. Mixture between HW and town.
