Huddleston
I know it is early and that probably no one has actually had the fix performed yet. But, does anyone actually know what the fix will involve? I thought perhaps one of you Canadians might have some insight through your dealer or from the notice you received from BRP. I've looked at my MC, and see no evidence of melting. I was looking at the setup, trying to envision what BRP is going to do. I suppose one could replace the plastic cover of the MC with a metal one. The exhaust pipe already has a small heat shield between the pipe and the MC. I don't know that a larger heat shield would make a lot of difference. The Cat is the major source of heat under there. I've seen comments suggesting that the fix is going to solve a lot of heat problems, but I don't see that happening. Again, does anyone KNOW what the fix will be?
