What is a bump skid?
The Bumpskid actually replaces the front skidplate, that is currently under the nose of your bike. It's thicker, tougher, and much larger. It also attaches solidly to the frame at the rear. ( Your oem plate just holds the front bodywork pieces, to each other. :shocked:
As such; it supports the front nosepiece much more solidly.
And you can get it with some pretty bright lights affixed to it! :D
It is a bit thicker, so your ground clearance will be reduced by the 1/4", that was previously mentioned.
But I twisted my BajaRon Front Shock preload adjusters up just enough, to get me back to the prior clearance amount, and it didn't affect my alignment a bit! :thumbup:
View attachment 133968 Here is a photo of a basic SpyderPops Bumbskid Kit.
P1010045.jpg Here it is installed....you can see the lip off the front and the little wings on the sides.
It covers the entire bottom of the front end to avoid damage and damage to the lip of the body. It is heavier and probably 4X larger than the stock skid.
