What happened to the 2016 ST Limited?
2016 UK line up
In reference to the UK 2016 Can-Am brochure only F3, F3-S, F3-S Special Series, F3-T, F3 Limited, F3 Limited Special Series, RT, RT-S, RT-S Special Series and RT Limited will be available to buy. No ST or RS available to buy in the UK.
From what I can tell both the RS and ST are only available in the North American market for 2016. So I would assume that they will both be gone completely for 2017.
I agree.. BRP seems reticent to eliminate a product outright no matter how little it sells but a phase out would be more their style...
Hi John,
I'm a new member and very recently picked up a 2015 ST Limited.
I was wondering how long you've had yours and how many miles on it to see if you've had any issues with your Spyder.
Any advice/tips are welcome, I recently learned the ideal RPM levels for shifting and different cruising speeds.\
Thanks,
Lu
Hi Lu,
We purchased out 2013 ST-Limited in August 2015. It was used and had 185 miles on it. Since then I have added another 3000 to the odometer. At my request, the dealership (Hollinger's, Ephrata, PA) replaced the panels with newer panels to alleviate the heat problem. They have also done a couple updates to the fuse box and something else (can't remember right now). One reflector fell off of a saddle bag, and Hollinger's had a new set of reflectors within a couple days.
As far as advice goes, read the sticky post in the general forum called Do's and Do Nots for New Spyder Owners. I found it very helpful, especially regarding shift points.
