Was installing a digital clock and voltmeter. While looking for a switched circuit to tie the clock with I found these just laying empty near the marker lights on the left side.
Everything is working, marker lights too, so anyone have an idea what the two leads might go to?
View attachment 178835. These two terminal wires are on the left side but do not have a similar terminal on the right side
PMK,
I believe you're right ! Yes, it does have power and remains on after the bike is turned off but not after the headlights go out. I can't find the other connector which probably has both connectors together with no terminal wires running out the chassis side
I'm just going to use a replacement connector and insert the bare terminals into it and leave it be until another time. Not sure when i would ever need that light. I don't ride at night.
Yes, I did and thanks for the help.
I had no idea there was a frunk light. Still have no clue as to
its usefulness if it only stays on for 20 to 30 seconds anyway.
