daveinva
Yes, it's still technically summer, but I like to plan ahead! :doorag:
Here's what I want to do to my RS:
1. At a minimum, one Powerlet port on the dash to power heated gear this winter.
2. Preferrably, *two* Powerlet ports on the dash to power heated gear *and* an accessory, a.k.a. GPS, radio, etc.
3. I want my only outlet, or one of two, to be switched hot so I can use it for a battery tender this winter.
4. I don't want to add an additional fusebox to my RS unless I absolutely have to.
5. I may, however, want to also add in addition to #1 or #2 heated grips to my RS.
From earlier thread searching, I found this possible solution:
http://www.powerlet.com/product/multifit-two-socket-panel-kit-48/183
From my reading, that kit will include everything, including the right length of wire, to run pigtail from my battery up to the dash. The kit includes a fuse already so I don't have to add a fuse box. One (or both? I don't know) of the sockets are switched so I can plug in the tender.
However, if I wanted to add the heated grips on top of the Powerlets, what are my options then? Where would I route those grips-- is there somewhere else I wire them in other than the battery? Would I then *need* an auxiliary power/fuse setup?
(Also, any recommendations for the EASIEST heated grips to install on an RS-- the "best" would be even better, but I'm looking for an easy install on my own if I choose to do it).
Reason for asking: I hate electrical work. HATE IT. But I think I can do the Powerlet by myself. But I know that I *don't* want to mess with another fuse box, which means that if I need one (either for the Powerlets by themselves, or the Powerlets *and* the heated grips), then I'll order what I need to order, and have a dealer install everything for me in one fell swoop.
Also: I know the power draw for the Spyder can be iffy, and that if you run heated gear you shouldn't also run the foglights (which I have). Can I run heated grips and the foglights at the same time okay? Can I run a heated jacket (I'll probably skip the pants) and heated grips at the same time, sans foglights?
