What AirHawk model/size for 2020 RTL ?
kdog
What Airhawk model/size are folks using on their 2020 RTL seat?
I assume it just sits there - been a decade or so since I had one LOL.
I'm assuming the AirHawk Cruiser R Large but just wanted to get any feedback from anyone already using one.
Thanks.
Thanks.
Large cruiser R
kdog, I have a large airhawk and and smaller like this: https://www.amazon.com/gp/product/B01A41OS84/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
AIRHAWK 11" x 11" Dual Sport Motorcycle Seat Cushion - Lightweight Portable Inflatable Multi-Cell Air Pad with Breathable Spacer Mesh Cover & Non-Skid Bottom
I like the smaller a bit better than the large. Good luck.
That's interesting. I'm leaning towards the Cruiser Large R (I'm on the bigger side) but I do remember having it on other bikes and it seemed to push against the sides of my legs a bit. I'll think about that 11x11 as well - thanks Bangorbob.
Sir, the larger size felt that it moved my inner thighs out a little. A little uncomfortable at times. I had the smaller left over from my 2 wheeler. Works out much better.
I have an Air Hawk 2 Cruiser Medium - 14"x 14", that I bought to use on my '21 RTL. Seemed to be the right size, but we only used it twice before getting an ultimate seat.
That's a good point Bangorbob - thank you. Much to consider!
You can also look for the Wildass branded cushion of the same size as the Cruiser-R. Just as reliable as the Airhawk I had before the valve stem base couldn't be patched. I've had the Wildass for about 5 years now.
I bought a smaller size, don't remember if it was a med or a small (mine is about 12" x 12"). I did so because the bolsters on either side of the OEM seat press against my sciatic nerve(s); a smaller Airhawk eases that pressure. Also, the shorter version, along with the little extra height, means that I don't spend so much time sittin' on my junk (sorry to all the ladies out there)!
Turns out I have a friend with a AirHawk Large Cruiser R that didn't want it for his Harley, so I did a 3-hour test ride with it. Feels good so buying it used!
Kday, I have a large and small. It depends on how things feel as to which one I use. I also have wool seat cover.
