Ben Burped
My 2010 RT began to "piddle" coolant whenever I parked it. I bought some UV leak detector fluid and poured one in the coolant. I started the RT and as soon as it got warm, I could see a glowing flow with my black light flashlight and fluorescence enhancing yellow glasses. Damn, it was way back there behind all the hoses. I removed most of the hoses, the radiator, and slowly worked my way back to the water pump and removed it. Damn again, I had to remove the clutch diaphragm cover and the whole clutch cover with it's 14 bolts to get the coolant pump shaft out. Finally, I thought it's going to be alright now. Wrong ! I discovered that the bearings for the crankshaft and the counterbalance shaft were missing quite a bit of the plating inside. My dealer courteously ordered a clutch housing and is going to try to get it covered under my B.E.S.T. warranty. Is this something that I can expect to replace every 10,000 miles ?
