Water ! 2017 RT Limited
jkoons
OK you all took care of my starting question. Now I was checking my batt. terminals and found a small amount of water on batt and also inside the fuse covers any ideals?
Condensation, that's my guess unless you got wild at the car wash!!!~Or you love surfing the BIG puddles!! Or do you have AC in the garage?? Going from cold to hot!!:dontknow:
Did run into a little rain last night and I did wash it this morning, may have be more careful where I shot the water. Thanks
If you wash it with a hose, pull the ignition key first, so water does not run down into the ignition switch. Let that protective inner flap close tight!
Ask me how I know... :banghead:
Putting a little lube in there, now and then helps also!!
