warranty question
7 Decades
I HAVE A 2010 RSSE5 WITH 11300 MILES ON TO DATE. MY QUESTION IS WILL THE WARRANTY COVER THE REAR BEARINGS ?
THANKS FOR YOUR INPUT :helpsmilie:
From what I understand the rear bearings are not a normal wear item and should be covered under warranty. I would contact you dealer or call BRP to verify.
On the contrary, rear bearings are considered to be a normal wear item, and are to be inspected/replaced every 12,000 miles. As close as this is, I doubt they will cover it.
+1 wear item...don't they wear out faster if the tension is too great?
I KNOW THE BOOK READS TO INSPECT AT 12000 BUT IT ALSO SAID TO REPLACE REAR SPROCK BEARING AT 31000. I HAVE NEVER ADJUSTED MY BELT. MY DEALER HAS ALWAYS TAKEN CARE OF THAT.I MAY BE WHISTLING IN WIND;). I WILL FIND OUT TUESDAY:clap::clap:.
THANKS FOR YOUR INFO.
