Warning!! Do not use the Insulation Snoopy used to wrap Gas Tank
I think that highlights the problem though of the gas tank reaching in excess of 300 degrees causing the adhesive to break down...
I have the Thermo Tec starter heat blanket between the gas tank and seat on the wife's RTS. It works good, cut the heat under the seat. I used the Thermo Tec cool shield tape on the fuel tank and it didn't stick.
Do you have a link of the blanket you used and any pics of it installed. Ours has always had issues with the heat under the seat. Especially in the summer. Makes it almost unrideable.
I used the Thermo Tec Cool it product. :shocked:
:roflblack::roflblack::roflblack::roflblack:
Oops....
