Warming up Spyder for oil level check
I was not as lucky. Dealer put in six qts instead of 5.4 and fouled the #2 spark plug. $700 job to change the plug and diagnostic.
Granted this is an older topic we are now replying too.
Very odd though, that slightly overfilled, by 1/2 quart of oil fouled a spark plug. I have helped other folks resolve constant, serious oil leaks that found oil leaking from the oil dipstick cap. Those were overfilled almost 2 quarts on 1330 series engines, and no spark plugs oil fouled.
More likely, the spark plug simply failed rather than oil fouled.
Curious though, was the $700 spent on a V Twin engine and not a three cylinder 1330? If so, those V Twins are known to blow excess amounts of oil into the airbox, and in some cases the engine does inhale the expelled oil. If truly oil fouled that could be a possibility for those machines.
