want to install stebel horn on 2016
stebel horn installed....very loud stebel 11690019 twin tone 137 db
RTS
dumb question where is the stock horn?
Is it under the heat shield on left side?
very pleased...the panel is the panel closest to the left light...not the 2nd big panel over...
At a local rally, I had a vendor install a Stebal horn. He said it did not need a relay. It was not louder than my OEM....I installed a relay and it helped a little but it sure is not what I expected from a Stebal....Marty, is there different models of Stebals? What do you have. Thanks.
:spyder2:
I installed a Stebel on on 2015 RTL in the location of the oem horn, and it was significantly louder. I used the relay because it prevents overloading the horn button which may cause premature failure. The horn button isn't cheap to replace, but the relay is.
model 11690019 Stebel air horn includes the relay...you need the relay
:spyder2:[
relay is needed to keep from burning up your horn's on off switch. the Stebel comes with a 30 amp relay however i suggest you get the universal harness easier to wire and it has a 40 amp relay included. It is 137 db. I just had my rear tire replaced and the guys were impressed with how loud my horn was. lol https://www.amazon.com/Stebel-11690...esktop?_encoding=UTF8&ref_=aw_cr_t_automotive
https://www.amazon.com/Universal-Pl...rd_wg=rKDCL&psc=1&refRID=KKMS6P4AKM45TR5YD0V9
