Wake up module
JCSMOKE
Ok I have decided that I need (not want) a wake up module for the bike. Please advise on the best way to go, I do not want to be cutting into the brake light wires so if there is a plug and play option, it gets extra points.:popcorn:
Go to http://tricled.com/ , down at the bottom of LED order page are OEM connectors the will connect in between your harness.
I too do not like cutting into the harness so these worked great, if your adding a brake module then get the 5 pin connector.
If your adding a wig-wag module like i did then you will need two 5 pin connectors.
