The continuing saga of the VCM unit.....Part is now on backorder until 10/21/21...I have spoken with the BRP cares line both though email and by phone. No one has one other than a used one I found on Ebay...interesting fact I found out looking for the part is that the VCM part number is the same across the entire onroad BRP line....After repair I am seriously thinking about going back to two wheels, a Japanese bike...I am going to lose a bundle, but everything I have read since having this problem says this is not a isolated incident....
Surely it can't be
that much of a problem, cos there's simply not all that many threads on VCM failures here... are there a heap more elsewhere that NO-ONE here knows about, cos no-one seems to have commented to that effect?!? :dontknow:
AFAIK, there's almost no discussion here or elsewhere referring to VCM failures, unlike the number of threads there are talking about VSS errors caused by riding the brake pedal or of late, dodgy brake switches; then there's all those threads on dodgy wheel alignments; quite a few on stripped front sprockets; numerous threads complaining about the crappy Kenda tires; a bunch on belt vibrations; and of late, there's even been a few on failing Left Hand Control Modules on recently produced Spyders!! :gaah:
But seriously, how many failed VCM threads have you seen?? Here or elsewhere?? Cos even
this thread didn't start out that way, it was discussing a VSS warning on dabikerguy's 2021 RT, which was probably due to the brake pedal/light switch, only it's sorta morphed into discussing your VCM issue, and as that it's maybe one of just a few threads, if that?!? :dontknow: Heck, given the difficulty you are finding in getting a replacement VCM, I'd think that's probably due to just a couple of things - 1. They fail so rarely that
NO-ONE has any 'spares' or set up a supply line of spares; & 2. There is a world-wide shortage of the components that they use to make these things so even that's going to take time.... If it was a 'less isolated' incident than it seems to be, then surely there'd be
some preparation for it?!?
