VSS fault come and gone??
dshogman
Started up this morning, temps in the high 30s. Fired right up but the VSS fault was on. So I shut it down and waited a few minutes, started again and all was well. 150 mile ride to Leakey, TX and back with no problems. I figured at the time I would just reboot the thing and that's what worked.
So, did I try to start it before the computer had completed it's thing? The only other thing that I had been working on this week was installing the back rest which meant plugging the seat sensor back in when done.
Thanks.
The computers are real touchy. This seems to be a common problem. When I am booting up, I just let the computer do its thing before I start interfering with it like starting up or something like that. As long as it does not do the VSS fault every time you start up, you are probably okay.
It is scarry for me when the computer starts lighting up for no reason though.
