Spyder2780
Hi All.....I have a VSS Fault Error/DPS error/Limp Mode on my '08 GS after I installed a brake light flasher module & LED 1157 bulbs. It was not a plug-n-play module so I had to tie into the two brake light wires. I wouldn't think that installing this would affect the VSS/DPS/Limp errors. Does anyone have any ideas? I've checked all my fuses and charged the battery overnight as I had a similar problem before when my battery wasn't outputting enough, so I thought that was the same issue.....Thanks in advance
