voltmeter gauge
wyliec
Can anyone using a kuryakyn led voltage gauge tell me how many green led's are lit when operating above 4,000 rpm's on your spyder? Mine is showing two and wondering if it should be higher.
Mine reads one green at idle 1400rpm, 2 greens during normal ops. never seen more than 2 greens
using an analog multimter, it ranges from 12.5 volts at idle to 13.5 at hyway speeds.
The reading is dependent upon where you are taking it.
You should be seeing around 14V across the battery at 4000 RPM & greater.
If you are reading the voltage elsewhere then it's anybody's guess between 12.6 and 13.5 VDC
Agree. I get 13.9 to 14.0 when riding, taken across the battery. With a heated vest plugged in and both front and rear grips on high, it drops to about 13.8 V. The BRP spec is 13.0 - 14.0 V at 4,000 rpm, high-beams on, heated grips on high, no other accessories turned on.
