Void Warranty
Doug
When your 2013 spyder is covered by BRP WARRANTY in canada and you make some aftermarket modifications on your own, for example change the sway bar (bajaron) and/or Elk shocks, will this effect or void the warranty.
Yes, no, and maybe... :shocked:
Unauthorized parts will give them ammunition if the busted parts are linked to them...
But unrelated systems would certainly not be affected.
So your swayBar and shocks won't affect the warranty on the stereo system; but if you have a front wheel hub bite the dust... :dontknow:
(Keep the stock parts around... Just in case!)
Not sure in Canada. In the US they cannot void the entire warranty, and can only refuse coverage if the warranty problem is attributed to or aggravated by the modification.
:shocked: I hadn't thought of what the Canadian part of the equation would do... :opps:
You'd best check up in Canada... Or do we have some members in here who can help out?
