pjweimer
I live in central Ohio and had an opportunity to visit Reggy to see TricLEDs various products as they were installed on his RT. I was primarily interested in products that would increase our safety. A few days later I ordered seven products:
A couple weeks back I finally started the installation of the LEDS. Previously I had installed Gear Brake's Brake Light Flasher Module (http://gearbrake.com/collections/shop/products/brake-light-flasher-module). That is the component that causes the brakes to flash as can be seen in the videos. Started at the back of the RT and installed the first three packages that I listed. Access to the electrical connectors on the RT was a challenge mainly because I didn't understand the sequence needed to remove the tail light assembles. The extent I went was NOT necessary, I removed the entire rear cargo assembly. But having done so I then understood what was needed to get the tail lights out. Here are two videos that show what I did.
I love these products and I think that it greatly enhances our visibility.
Next I installed item 6, the long distance high power LED spotlights. Actually I have yet to wire into a power source for these lights. Thinks about adding a Fuzeblock to support these lights. Here is a video I shot yesterday of where this project is at the moment.
I hope to finish this project today and move on to the remaining packages.
- 2 piece center run/stop dual functioning LED (3rd and 4th brake light)
- Top LED Light Bar (another brake light)
- Saddlebag run/brake/yellow turn signal (I really want whatever is behind me to know that I am slowing down)
- Rear Saddlebag LED
- Safety LED Super Package (amber reflector and rear red reflector)
- Long distance high power LED spotlights
- DRL white LED & dual color with yellow turn signal
