Vibration at 67-75 MPH on F3-S
Smallz
Has anyone noticed a vibration when you roll on the throttle at 67-75..worst mostly at 69ish-71? It is a pretty strong grinding feeling.
Likely it's your drive belt vibrating. Same thing occurs on my RT-Ltd at about same speed. A belt idler wheel (available from 2 of our sponsors) solved 95% of my vibration problem. Also might be your belt is not at the proper tension spec.
Thanks! An excuse to ride! ( not that I needed one )
I know I had at least 15 minutes of speeds from 75 to 80+, didn't notice anything ( but the wind ). The F3 felt very stable and smooth - more so than my ST-S.
I'll go out in a little bit and check.
Tom
New ground...
your the testers and solution finders. We will wait and see what that solution might be. Being day one for this model (basically all new) that that affected us in the past may not apply here. Will be interesting to find out. Would appreciate your letting us know so we can learn the "what to do if" ...:thumbup:
No vibrations
I didn't ride for long, mid-40's and lots of wind, but no vibrations at the speeds you mentioned over a 5 mile strech - other than my teeth chattering.
Every ride impresses me more.
Tom
I have a tensioner in the works for the F3, along with a backrest.
I took the demo from my dealer for a 35 mile ride and the vibration was quite pronounced, my wife even noticed.
My demo was set in Kilometers and it was around 123-125 which converted to 76-77 MPH.
My magnesium SM should be here any day, I can hardly wait!
My LG headset that I had worn around my neck for a year blew off and got ran over in the first mile, I haven't even taken delivery and it's already costing me. It was worth it though.
Longer Belt
I was wondering since the F3 has a longer belt to accommodate the larger rear pulley. I am thinking a longer belt would have more amplitude and vibrate at a lower frequency than a shorter belt. That would maybe explain the grating feel when it vibrates. Like any belt drive the tension and alignment are critical. With so few F3s out on the road it's too early to tell if this is a production set-up problem or just harmonics from the belt itself.
I would be really upset if I have to buy an aftermarket piece to fix a problem with manufacturing. If they didn't put a strong enough belt tensioner on it then they should take responsibility and fix it. Other then the vibration it is an AMAZING ride! So fast, low end torque is just AWESOME. Mine had damage on the frame we discovered when they moved the pegs from position 3 to 4 which BRP/dealer is fixing/replacing. The tranny can be a little rough at times on the SE6 but a neglagable amount. DEFINITLY needs a windscreen. I ordered the Blue Ridge yesterday, it is on back order and won't be here until the last week of Feb :(. I also ordered the RAM mount and a USB charger so I can use my phone. I am looking for recommendations on in helmet bluetooth systems. I want to be able to take work calls while on the bike and am looking for something that will cut out the majority of the background noise.
It's not a problem with manufacturing... It's just a harmonic vibration from the belt. Pretty much inevitable with any belt drive setup.
Non of my three belt drives on my three Harley's ever did that Bob. Nor has any of my belt drives vibrated on my two Spiders. Belt is loose or not aligned properly is the culprit.
Jack
The backrest that your working on, will you be designing it for a luggage rack and if so will the rack be removable?
A LITTLE VIBRATING HUM
I took my F3S out for a little exercise today, and I too noticed the vibrations between 67 and about 72. I will put a few more miles on it and then take it in to see if the vibes can be adjusted out, if not Ill be looking for a belt tensioner.
I'm NOT saying that it can't be tuned-out...
Orrr... was everything else shaking so much, that you just couldn't feel it?? :D
I can tell you have never ridden a Harley Bob. !00 MPH - Pipes a blarrin - no helmet or is it helmut - fifty bikes and your are leading the pack for the next 1500 miles to Disneyland (Sturges). Oh what a feeling. Vibration I hear no stink'n vibration.
I do miss that! Now I have to ride with all you old slow farts.:D
Jack
Due to the diminished storage, I have a rack planned also. They will both attach to a main mounting bracket.
Installing either the backrest or rack will require the same mounting bracket, you will be able to add or remove either piece with minimal labor.
The backrest will be first, after that I will be looking for opinions as to what size rack will be needed to satisfy the needs of most.
For those that like to remove their rear fender, the rack will also serve to keep their passengers backside dry on wet roads.
:clap: :2thumbs:
Oh; but I HAVE... :D
I will say this for them: they have the best-made mirrors on the Planet... nojoke
If they weren't so good; the glass would pop out of them in a heartbeat! :roflblack:
A follow-up
After the snow/slush/rain stopped this morning, I took the F3 out for a good run. About 30 miles of 65 to 90mph. No vibrations. Nothing in either 5th or 6th gear.
I was impressed at how stable and in-control the F3 was. I really like this machine.
Tom
There You Go....
It kinda looks now (still early to tell as not many F3s on the road yet) like the OP of this thread might have his belt out of adjustment, either tension or alignment or both. Just a guess since his does vibrate and this other fellow's doesn't.
