Illinois Boy
Really? Shouldn't break-in rpms be below 6k? Isn't that normal practice for a V-Twin?
Breaking-in an engine will provide as many differing responses as an oil-thread.
Personally, I would not run mine up to 6,000 rpm's during break-in; however I would (and did) ride mine quite normally during break-in (5,000 to 5,500 rpm's) -- EXCEPT I never maintained a constant speed -- ever during break-in.
It is highly recommended in just about every version of break-in procedure to use varying speeds often and to never ride for any distance at a constant rpm. As I mentioned, I would avoid over-revving the motor early-on -- especially if there is not a load on the engine. That's a good way to spoil a new engine quickly. However, riding around in the range between 5,000 to 5,500 rpm's should be fine in my opinion.
Lastly, many would suggest you change the oil well prior to the recommended break-in period due to the initial metal-shavings that typically occur in the initial few miles (and I literally mean within the first 20-50 miles). But each to their own on that matter.
To the OP's post... with the 900 series engine, you had better learn quickly to run your Spyder at a much higher rpm's than you ever did your Harley. Running a 900 series engine between 2,100 and 3,500 is killing it -- period. You need to think of the 900 series engine like you would a sport-bike -- not a low-torque v-twin. You will more than likely find running the engine at 5,000 and higher will smooth-out the engine and quiet it down some. Try to get over the idea you have to shift to the highest gear (4th or 5th) no matter what speed/rpm's you are going. You can ride all-day in 3rd gear up to 55 mph. Save 4th gear for 55 to 65 mph. 5th is for 65+ on relatively flat-roadways. On hills you'll be shifting between 4th and 5th frequently to keep the rpm's up.
Good luck to you...
