2018 RTL
I'm about to embark on a wiring disaster (er....project) and need some assistance/suggestions before I begin. Have a few electronic gizmos on the bike now and plan to add a few more before I'm done so I think it's time to add a fuse block. Currently, I have my phone w/a USB cable run to the frunk connection. This works but I'm considering hard wiring in a power connection as I never use the BRP Connect (and personally think it's not ready for prime time....maybe on my next Spyder). I have an XM receiver already hard wired into the OEM fuse box. Impossible to get the fuse box cover to stay on. I just picked up a Garmin 660 GPS and need to hard wire that, too. I have plans to add a few more lights, LEDs, etc to the bike and want a good place to plug them in without overloading something and/or catching the bike on fire (which is probably what will happen anyway).
I read https://www.spyderlovers.com/forums/showthread.php?116532-Fused-electrical-distribution-block (very informative but a little confusing to me). I'd like things to be as plug-n-play as possible for 2 reasons. First, I don't have a garage. The less time spent with the bike torn apart, the better as I can't just leave body panels off, frunk open, etc if it rains. Second, I'm not good at fabricating things. Running wires here and there is one thing. I see INfox used the FZ-1 fuse box which looks like it has an integrated relay. Pretty expensive @ just under 100 bones. Is there something else that is similar for less green? I think (and I could very well be wrong), someone mentioned using some accessory plug buried behind the frunk for switched power. I've read that it's difficult to get to and that (maybe) the entire front end has to be removed to access this. (Why in the heck would BRP add an accessory plug that's impossible to get to???) I'm NOT removing the front end of the bike. Just not gonna happen. Is there another way to access this or is there a better place to get switched power for the relay? Is there a good place to run all of these wires from the dash, etc into the frunk? I've got a couple wires running over the top of the frunk (where the snaps are for the liner). That's NOT a good permanent solution.
Finally (and this seems like a stretch), is there anyone in my area (anywhere within a couple hour ride of northwestern NC) who has done this before and would like to earn a little bit of money either doing the job or at least walking me through the job? (Your garage, your tools, your knowledge, my labor) I'd be willing to pay someone but I'm NOT paying the shop $100/hr to do this. I'll muddle through it before I do that.
Any help would be appreciated. I'm getting stressed out just thinking about this as I really don't know what I'm doing and I'd like to plug in my GPS, etc.
TIA
HAGO!
TIA
HAGO!
