Deanna777
Well-known member
Could I have a link to this please, so I get the correct one?
Could someone else chime to post a link.
Deanna
I am using the Valvoline Full Synthetic SAE 10W40 Motorcycle 4 Stroke Motorcycle Oil (this is for the Ultimate Wet Clutch, Transmission & Engine Protection).
It is formulated for the specific needs of high performance 4 stroke motorcycles, including high temperatures, high RPM's and Wet Clutch Systems.
Full synthetic formula for the ultimate protection against wear, deposits and corrosion that can decrease engine performance.
Developed with advanced additives to resist oil thickening and maximize horsepower.
Outstanding wet clutch protection for maximum powder transfer & Smooth shifting.
Meets or Exceeds JASO MA2 API SL
I have been using the above oil since 2014 (in my 2014 RTS-SE-6 SOLD) and I'll be using the above oil in my current Spyder (2023 F3 LTD Special Series). I have not had any problems with the above oil.
Deanna
"...... been using it for 67 years now .....Mike :thumbup:
Wow that long MIke, Boy that's a lot of loyalty. (ooops?)
Oh it's low all right. Zero.I use and like that Valvoline ....... here's something that might not be known about the Valvoline - Out of about 20 of the leading Mtc oils. This Valvoline had the second lowest Molybdenum added to the product, only Amsoil is lower ........... Moly is BAD for WET clutches .... and the Spyder has a Wet clutch .........Mike :thumbup:
I was just looking at Vavoline web page and it listed Pros and Cons for the 10w40 motorcycle oil. In the Cons side it said you could only run 600 miles per oil change. What in the world are they talking about.
600 miles - :lecturef_smilie::roflblack::roflblack::roflblack: ..... JMHO Mike :thumbup:
