Utopia Seat Question
bobgeorge
Hello all,
I got my Utopia seat & got it on this weekend. Question, my wife jumped on the back and she said the metal attachment at the bottom rubs against her if she leans forward. What do you all use to protect against that?
I should add that I have a BRP heated comfort seat so I am seated 2" back.
Thank you!
HUH
I think you mean you have a UTOPIA BACKREST.....right.....because of the extra room you have ....the passenger gets less....That's the way this seat works.........Utopia does have the POUCH on the back...put some foam in it ....or wrap the metal post..............good luck..............Mike :thumbup:
Utopia Backrest
I think you mean you have a UTOPIA BACKREST.....right.....because of the extra room you have ....the passenger gets less....That's the way this seat works.........Utopia does have the POUCH on the back...put some foam in it ....opor wrap the metal post..............good luck..............Mike :thumbup:
Correct...backrest. I will try some foam wrap around the metal.
:agree: I think Utopia sells a wrap for the post. If not, you can probably improvise with a strip of leather and some velcro. Unfortunately, this is a trade-off with the comfort seat, it offers comfort for the pilot, at the expense of the co-pilot. That's why we stayed with the stock seat.
Good luck. Hope you find a solution.
Pam
Yup! Contact them! :thumbup:
If you adjust the backrest to be a little bit more forward; does that help her out? :dontknow:
Same issue here, but I think you are taking about the eyelet for the bolt that sticks up to the rear of the bracket. The only way around that is to get the Easy Out bracket. There is no eyelet. We have the padded wrap for the bracket as well but doesn't help with the bolt eyelet.
SOLUTION
SEE THE PIC IN POST #7........I made a lower bracket for another Spyderlover here because He also had a Passenger issue. In the PIC shown I made His bracket so the opening was closer to the operator, which gave the passenger almost 2 inches.......just sayin....Mike :thumbup:
Thanks for all the info. I guess I am taking about the bolt eyelet. It protrudes back toward the passenger a lot.
@BLUEKNIGHT911
- I'd appreciate any info on what you did with the eyelet.
HUH
@BLUEKNIGHT911
....Is yours ...EXACTLY ...as in POST # 7 shows.........Mine is an easy-out and I just turned the slide- in bracket around so that " eyelet " is under the backrest where it doesn't bother anyone........The one I made, I did it the same way......If you can post some PICS maybe I can help you with yours...........I'M NOT A VENDOR BUT , I try to HELP PEOPLE WITH UNIQUE PROBLEMS... Mike :thumbup:
Here are photos of what I am talking about.
attachment.php
attachment.php
Any recommendations on covering the bolt/eyelet at the bottom of the Utopia backrest? It's still bothering my passenger. Thanks!
