But really, in this aspect I think the Spyder it is what it is and, for the most part, we need to learn to ride within the parameters it gives us. Done correctly, you can really get all there is out of this machine in most cases.
This will be a must see :chat: :ani29:So the wing project begins:
I ordered a kewlmetal luggage rack
http://www.kewlmetalstore.com/product_info.php?cPath=5_42&products_id=109
This is the frame interface
Next I'm ordering this wing 36" wide
http://www.pro-werks.com/partlist/831/
According to the data sheet
http://www.pro-werks.com/common/support/SolutionDetail.aspx?SolutionID=25
I should be able to get
32 lbs @ 50 mph
130 lbs @ 100 mph
At 80-90 mph that's about 10 percent of total weight
32 lbs @ 50 mph
130 lbs @ 100 mph
I wouldn't expect anywhere near those specs, the airflow is too dirty by the time it gets there. Those specs are most definitely direct, clean airflow. Things would be a little different if you were shaped like a vertical stabilizerSo the wing project begins:
32 lbs @ 50 mph
130 lbs @ 100 mph
Looking at a F1 car, the entire thing is streamlined to produce the least amount of wind drag and puts the wings (front and rear don't forget) in the best possible location for down force. Plus they don't do much at all at low speeds, regardless of design. You have to have airflow to create the lift/drag. Airplanes don't fly at 40 mph unless they have large corded wings and lots of curve (flaps, slats, slots and other lift producing devices).A formula one car's rear wing can only be a meter wide the same width I'm using
