IdahoMtnSpyder
Well-known member
I'm in Omaha, NE tonight on my way home from Deadwood 3 wheel rally followed by a trip to eastern Iowa to see my son and family.
The starter button is not working reliably on my '14 RTS. It's gotten to the point I have to push up on it to get it to make contact, and then it doesn't always stay in contact. It usually takes two or three times to get the starter to engage long enough to start.
Have any of you taken the right hand multi switch apart and know how the starter switch is built? Is it a bubble switch or a real mechanical contact? Have any of you tried cleaning the switch?
I don't know right now if my subscription to Remote PC is still active or not. I'll check it after a bit. If so I can download the wiring diagram and figure out if the start circuit is Can Bus or direct connection. I suspect Can Bus which will complicate fixing it.
If anyone can share some real experience I sure would appreciate it.
