Upper Right Radiator Exhaust Block-off Plate
Bangorbob
I received my block off plate and took off the 2 bolts on the lower panel as suggested for a 2012 rt. Question is: what is the secret to finish taking the panel off? It appears there is a bolt that holds it on the left side as you look at the panel.
Thank you for the response. I neglected to say I did read the instructions. Just don't quite understand "snip the tab holding it". I am assuming that means to cut the plastic.
