Unstable ride feeling........
Just because a couple of you think this is not an important subject.......or has an easy and obvious solution.......or can't bear newbies trying to get a handle on the "problem".......
Get over yourself.
If the subject upsets you, don't read the thread.
Simple.
Taking mine in today for 3K service and laser alignment.
We will see.
It took me a 1,000 miles
I'd been eyeballing Spyders for a few years so last June I rode a new one for MAYBE 30 minutes at my local dealership. Wasn't sure I liked it and felt very, very nervous - also, letting go of the handlebars showed me how truly horrible the alignment was.
A couple of months later while on a vacation riding my Yamaha VStar 1100 a long way from home, I saw a Spyder I liked with the right price and traded in the old bike. Even with my questionable experience with my test ride I figured I'm as capable as the next guy and can manage getting three wheels down the road. My new Spyder didn't have the same alignment issues as the one I'd test ridden, thankfully.
The next day I rode it home on the interstate - 850 miles.
Add on a couple of thousand miles later and I now I'm riding it like I stole it.
We will see.
Hope this does it for you. But, some dealerships will SAY they have laser alignment because they know that is what customers want. So be careful there. Then, some have the laser alignment equipment but it isn't magic. It takes a skilled technician that is willing to spend adequate time to do it right. That is harder to know.
You might also want to check belt tension when they are done. 'Trust but verify' can be a good way to look at it.
Not trying to throw a wet blanket on your decision. I think you're going in the right direction. Just giving you information that others have learned the hard way.
Good Luck! :thumbup:
Thanks for all the advice.
Pretty sure that they HAVE the proper equipment since they are listed on the dealer list of the guy who makes it.
Now.....whether or not they really know how to use it...............:dontknow:
The service manager did say that they would test ride it to see if they could spot anything else that might be causing the problem.
It is beginning to look VERY much like there is no "fix" for the complaint that I have.
Unless maybe tires with a different tread pattern would help.
My service guy, who seems to have a lot of Spyder experience, said he did an extensive test ride and everything appears "normal" to him.
Said he certainly could do a laser alignment if I insisted.....and charge me for it.......but seriously doubted that it would make any difference.
He did reset the "steering angle" and "torque angle" sensors.....and took out the extra 5 LBS of air in the tires.......and on the ~50 mile ride home I couldn't tell much difference.
At this point, I'm gonna put the extra air back in the tires and just learn to live with it.
I did note that getting the back tire on a crack or joint in the pavement can make it act REALLY squirrley and I suspect that smaller versions of that is the feeling that I don't like.
It is getting better the more miles I log.
Thanks to all for the help.
sounds like way too much air in the tires to me
"learn to live with it" as has been suggested many times is a great idea.
In 1500 miles or so, you'll be over your fear and enjoying your Spyder.
Last resort, list it in the for sale section
you may actually be happier in the long run if you did that
Like I have said on this before. The roads all over this country are aweful. Heat & cold and all the traffic causes ruts in pavement. If you can go out early in the morning and take rides on different roads and see how it handle on each road. Then go out and ride in the afternoon on the same roads and see if there is a difference. Then ride the opposite direction.We have a 2011 RT and it does great. Some days it rides different on the same roads we travel all the time. Whether its hot or cool at the time we ride. Just try it. You might see the signs that it not the bike Its the highways you ride on. Or it could be that you've gotten so dishearted with the machine that nothing is going to make it happy for you. Not trying to being rude. Just trying to help. Do something like this before you go out and spend a bunch of money.
How much is "way too much" ??......and why ??
I am at +5 in all 3 tires, which is well within the max safe rated pressures.
That makes the sidewalls a bit stiffer and less likely to "wander" sideways with small inputs.
I LOVE MY SPYDER.......overall.
I just don't like the FEEL under some conditions.
I AM going to "get over it"......whether I really do or not.
That does not deter me from trying to minimize the problem though.
P.S. I'm well over 1,500 miles already......and it hasn't "scared" me since I got past the first hundred or so.
Good for you. At least you are trying and not just throwing in the towel or the baby with the bath water. No pun intended. It may take more time but you'll get there. Only time will tell. Have a great weekend.
So you trust the mechanic who overfilled your oil by a quart enough to tell by just riding your Spyder that it doesn't need an alignment? I don't get what your aversion is to just paying for the laser alignment. Makes me think no one there knows how to run the machine correctly.
:bdh:
You know without putting the equipment on the spyder it's hard to tell if it's off to someone who doesn't ride a spyder much. I would go to the guy who invented the system.
Yes, those things taken together bother me a bit too.
My "aversion" is with spending money on things that are really NOT indicated.
You guys had me convinced that it would be worth the gamble though.
I may spring for it yet.
But I'm still playing around with tire pressures.
My latest test is with fronts are the recommendation (20) and the rear at about +5 (33) and it seems much better.
But the last experiment seemed better too......until the next day when it felt worse.
Going +5 seems counterintuitive to me, especially for a guy who feels the Spyder is unstable. Stiffer sidewalls should cause it to wander more, not less, because they would be so responsive to the slightest steering input. They also would seem to contribute to a jittery feeling on the road. That's what more air does to my car tires and I don't see why it would be different with the Spyder. Deep down, though, I don't think the problem is in the air pressure at all. A few pounds up or down shouldn't make much difference at all.
The thing is that the more air you put in a tire the more it raises the outside treads up so that all your doing is riding on the middle section of the tire. Which will make the center of the tire wear out quicker. Its just the opposite with less air. The outsides wear and at times will start to cup out on the edges of the tires. Look at the owners manual and see what it says to use for tire pressure. Find the happy medium for the tires. I run 17 in the front and 26 on the rear. Never had it lazered and it rides just great. On our 2011 RT with 47000 on it.
WELLLLLLL NOW THAT YOU MENTION IT
The advice above ONLY applies to KENDA tires ......auto tires are at a minimum 3 times as strong as the Kenda, and are far more tolerant of the PSI you use ( on a Spyder )..... Unless the PSI in an Auto tire is off the charts above or below reasonable pressures ... the Tread will pretty much ride flat ...... But Auto tires on a lightweight ( compared to a car ) Spyder should be at lower than normal PSI in order to give the best the tire can offer .......... Mike :thumbup:
