ultra touring windscreens
GS1
good day all, i have questions about the ultra touring windscreens,i have an 09 RS SE5,i have been looking at them and have found different part numbers for the 25 inch ones. Are some narrower in the main section, the pics i have seen lead me to believe that there are different shapes. I want the wider one. Also how do you like them.
I have a 2012 RS-S and the 23" screen there were no additional parts required it mounts in the same location ans the original.
I think the question was about width and I think that depends on if you are getting a OEM part or aftermarket. jtpollock
I have had 2 2009 GS's. I also have 2 Touring windscreens one is a BRP with the humps for the handle bars which is GREAT here where it tends to get a little chilly in the winter. I also have one that is similar with out the handle bar bumps which is like the stock one just a wee taller. I would say for ryding around town stay with the shorty, maybe get the carbon fiber shorty like I have!!
Both my OEM BRP and my aftermarket mount the same way I didn't need any additional parts.The width was not a problem at all!
windsheild
:doorag:
Two years ago I bought from C-Bailey their 24" touring winsheild for my 2009GS
No regrets, works well and also less $$$ than many others, check out their web site,
Cbailey.com:shocked:
I do believe there were different part numbers for the touring windshields. There was definitely a slightly different shaped one installed on other Spyders at local dealer.
I bought a 2010 RS with a touring shield. It had brackets and you can see them in this BRP link:
http://store.spyder.brp.com/product/769501/219400285/_/Ultra_Touring_Windshield_Kit
Close up from the same site:
http://mediacdn.shopatron.com/media/mfg/4630/product_image/03b3bdafa7fa5dd4d4aed6109fa12935.jpg
It didn't work well for me, horrible buffeting, so I sold it. From best I can remember, the holes in the shield lined up with the brackets but not the spyder body so it would not mount without the brackets.
I put on the OEM ultra touring 23", with the wider bumps for your hands. The holes in it do not line up with the stock holes and require a bracket. There is also a matching 25" version that mounts the same way. I'm 5'7" and the 23" is perfect, sending the air flow just above my helmet. Taller riders would need the 25".
attachment.php
The sport touring fits the standard mounting holes, but doesn't have the hand bumps, but it is only 14" tall. I have seen a narrower one, without the hand bumps (same width as the sport touring) that is taller, probably close to the 23" or 25", and fit the stock holes, but it wasn't OEM. Not sure what brand it was.
Cy
I put the 25" touring screen on our 2010 RSS and it screwed right on as well. It has been a great addition. I love how when it's raining you can move your helmet to a certain level and angle and the all the water gets blasted right off your visor!
My 2 cents....
I installed the 23" touring on my 2011 RSS and it does have the additional brackets which in addition to create a wind gap to help form a nice pocket behind the windscreen , it also changes the windscreen angle which keeps the top edge from protruding to far aft.
I'm 5'8" and the top of the windscreen falls perfectly at eye level such that I can lower my head and the airstream breaks over the top of my helmet visor. Or sit up just a bit and look over the top. Very pleased with the purchase.
:thumbup:
25"
I have the 25" with the handle bar dams , works great . Although I loved the air rush that I have missed being off a bike for a few years with the stock short shield , it became a bit much on longer rides on major highways . Yep it helps big time if it starts to rain as well
My Thanks
you guys are the best the info given has helped me figure out what i want to get for my next addition to the :spyder2:. will post pics as soon as i get it installed:bowdown:
25" installed
Got the windscreen on Monday night, installed it on Tuesday after work,read all the post about the plastic screws and still broke 1 replaced with the old screws. i rode in on Wednesday (33 deg) there was a clam from waist to head, had more air flow around the legs ( didn't get the deflectors ). thank you guys for all your input looks to be 1 of my better buys.
attachment.php
attachment.php
attachment.php
attachment.php
Deflectors
I suggest you find a set of the deflectors that came as part of the kit with the ultra touring shield you have. The windshield and deflectors were designed together, and work best as a set.
i have the taller oem windshiled and baker air wings on my 08 gs and unless there is a tornado i dont feel any wind at all, have to change to shorty in mid summer to keep from overheating but use tall on most of the time
Quick update on my windshield adventure:
I sold my touring screen to another member here that was local. I see he finally put his bike up for sale on CL. The buffeting was just too much for me @ 6'2" with bar risers and comfort seat putting me further back than stock riding position.
I ordered a 24" Madstad based on the information on their site. Big improvement but over 65 mph I was still getting buffeting no matter where I put the shield. I also couldn't really use it at the settings they suggested so had it all the way down and tilted as far back as possible which meant a lot of wind noise.
Contacted Madstad support and worked with Blair/Mark to get a taller, 26", shield cut. Just got that installed last week and it works perfectly. It is set about 1" from the lowest setting and near 60 degree tilt as they suggested. Finally I enjoy riding at interstate speeds. Sure, it is a big shield but I don't mind and the buffeting was a real deal breaker for me since I am the only one that drives the Spyder now.
Tip on those unsure and shopping around for shields, keep the plastic cover on that comes with the shield or wrap in plastic kitchen wrap to protect. Clear packing tape can be used to secure the extra plastic so it doesn't flap around. Carefully poke holes through the plastic for mounting. This will keep the shield protected and should allow for a return/swap if needed. Doesn't look pretty but might save you a restock/damage fee.
