Ultimate trailer
Paul Ski
Im looking at buying a trailer to haul my 2014 spyder rt and my rt 622 pull behind. My question is does any one own a Ultimate Trailer that can carry both?
We recently sold our UT as we now have two RT's. When we hauled the one RT on the UT there was very little room after the bike was loaded. I don't think your trailer will fit with the bike on the UT.
I have a single axel covered trailer that would carry both. If you look at "standard" covered trailers, make sure you get one with the extra height - mine is 6'6" INSIDE. This gives you a longer ramp, and better ramp angle to load the RT.
Depending on what you pull it with, you may also want a "V" nose to lower the wind surface, but would need to add the additional 2 feet to the length of the trailer. Backing the Spyder into the "V" nose, keeps the weight forward, and give the max room for your 622...
Hope that helps.
Ultimate trailer just came out with a trailer meant to carry both the Spyder and 622. It is two feet longer than standard.
