Ultimate Seats 2012 Install Issues
Brogers57
Hello,
I tried installing Ultimate Seats today and have ran into a problem.
- When the seat latches I can pull on the left side and un latch it plus it becomes really loose. http://videobam.com/SBcay
- There is a small black square bracket on the Ultimate seat but no the stock one?? (See Picture)
Help!
This is just a wild guess ....
Just a guess but I am betting you are doing something wrong... re-read the instructions you must have missed something.
Hello,
Help!
It might be the steel plunger pointy thingy that goes into the latch. It's length is adjustable and will make a difference on how well it will lock down.
The pin on the seat is adjustable front and rear about one inch also it adjusts in and out once u have the alignment correct front to reat than the pin should be down so the seat clicks and locks if not loosen the nut and back out the pin to the left until u hear it lock.
Mike
Ultimate Seats - Install Help
Hello,
Help!
Brogers,
Please give Russel a call Monday morning if you are still having the issue. He'll be able to help diagnose the issue. 877-672-0288.
In the meantime, you can watch our installation video here:
Best-
Thanks. I got everything fixed. Sadly I had to return the seat. Got the Low Rider and it's way far up for me. Exchange for the mid rider :D
