Bob Denman
:shocked: So I'm outside starting up my Spyder and once the fuse was lit, the engine just didn't settle down to a 1400 rpm idle. It felt "disconnected" from the throttle as I tried to rev it up to clear its throat... almost like a vacuum leak or something! As I started down the road it would rev and bog; THEN IT DIED as I manually downshifted into second gear! :yikes: Now I'm figuring out how to make a RH turn into a parking lot without killing the entire Town... that part worked out fine! :shocked:
Now it's stalled, I can't downshift into neutral and since the Parking brake won't engage I'm sounding like a phone company truck backing over a goat! I grab the toolkit... (those who know me know that this is when you go get a beer and pull up a lawnchair!)
Wrench in trembling hand, I stuff myself under the Spyder and try to find that shaft that you twist in order to downshift when your life has turned to :cus:... NO LUCK!
Well I turned it off and on a few times and then it started and sounded pretty good! (in first gear though...) I took it back to neutral, threw my tools and manuel back in the frunk and headed off... Running like a million bucks...
So what happened????? :shocked:
What should I tell the dealer as I cry into the phone??? :gaah:
