two brothers exhaust issue
cowboys
i noticed alot of hesitation in every gear. anyone have any thoughts why this maybe happening. i just put it on. i also unhooked the battery for about 15 miniutes. still the same results. im about ready to move back to the stock pipe. any help would be great. i do not notice any exhaust leaks anywhere either.
I don't know about the Two Bros. I just put on the Hindle a couple of weeks ago. The instructions stated you have to let the :spyder2: idle for 15 mins and the then cool for 15 mins before ryding. I do notice my :spyder2: missing alot more than the stock pipe until the engine is warmed up to 3 bars.
did you put the pips on or the full header on back...... because if you put the full exhaust on then you need to add fuel..... what eles do you have done to the spyder???
pipe issues
it is just the carbon slip on. im ready to move on to the stock. i just got back from a ride and it sucks.
After changing out my stock muffler for a Two Brothers. Mine ran like crap. Didn't want to move until 4000 rpm"s. With the stock muffler I had to hang on from the first twist. I got rid of the air box and installed open air filter. Still ran like crap. Then I found out my throttle grip was slipping. I bought new grips from Harley shop. When I get her back from the dealer. I'll install them. I will get all the bugs out sooner or later. :gaah: Probably just in time to buy a 2010 model. They better have all the bugs worked out by then.:chat:
That would be the O2 modifier: http://www.evoluzione.net/canam_o2_modifier.htm
Would probably work. I am in the process of switching out my stock can for a setup from Ken at Evoluzione so no experience yet.
Given you have a Two-Bros you might consider their Juice Box designed to work with their pipes and the Spyder.
While the Hindle looks and sounds GREAT it has the similar back pressure/flow characteristics to the stock can thus no need to really futz with anything else.
Most aftermarket pipes - especially the Two Bros - are pretty free flowing and and can - not always for some unexplainable reason - require some mucking with the fuel flow.
I have the Two Bros on both mine and the wifes Spyder. They both have great throttle responce, they do pop a little on deacceleration. We both have the SE5 model when i first put it on they wouldn't down shift by them selves untill i added the power tip that gave it better tone and allowed the proper down shift. My dealer said it probably needed the back compression?
