How can I turn off my RT speakers so that my music can only be heard through my helmet headset speakers?
Yep, that's how it is done,,:bowdown:I'm going off the top of my head...
Press your mode button till you get to the set up screen.
Toggle down to audio (?) or to speakers(?).
Toggle over to on/off.
Poof... they're off. No need to mute or disconnect.
Look for the "External Speakers" setting and turn it off (or maybe it's disabled).
Note that while the volume control does not affect the sound volume to the headset, muting the sound will also mute to the headset.
Thus only way to not hear the speakers is to lower the volume on them as low as you can without muting them.
Bob
That is not correct. Turning the external speakers off as stated by others above will silence the speakers and leave the BT unaffected. But turning the speaker volume down is my prefered method.
Dont know why you would want speakers on mute:dontknow: most people are looking for upgrades to be louder. But to each his own. With that open the tupperware, should be ez enough to unplug the speakers. Id duggest only undoing only 1 wire per speaker & protecting the end (heat shrink or electrical tape)so will not short out accidently. You could ziptie the wires together & keep them from falling fown into hard to reach spots on the bike. You may want speakers eventually. Good luck:thumbup:
Mute the speakers as suggested. Go out and by a Sena or Cardo unit and pair it with an iPod touch or your music loaded phone and then you don't ever have to use thos horrible sounding speakers!:yes:
I guess we are talking about 2 different things. Shutting off the speakers via the menus you are correct. I was talking about mute not shutting them off via the menus. So the terms we use confuse
However with that said... you won't be able to get into the menus if you are moving to turn them off that way. BRP decided it was not safe to allow you to do that while moving.
Bob
If you are rarely or never going to listen to the external speakers it would be best to use the, turn the external speaker off option. If you wish to switch back and forth between headset and external speakers, it would be best to turn the volume down.
But then you don't see the music menus on the dash. Kind of hard to navigate through 1,100 songs by stepping forward one after the other.
Well unless you have your phone on the dash and can manipulate the screen which is a NO NO and as bad as texting while driving :lecturef_smilie:
Bob
